2nd Gen Non-Engine/Transmission Repairs for the DEATH WOBBLE
2nd Gen Non-Engine/Transmission wheel bearing
2nd Gen Non-Engine/Transmission Track bar what the !!!!!!!!
Here is a copy of Brents alignment specs with a good explanation.
Anytime I get an alignment I make sure it is followed to a 't'.
Luke's Link won't fix wobble, but it sure eliminates wander. As you drive the ammount of steering correction made becomes automatic and tiring. Luke's repair kit eliminated wander, feels strange going straight down the highway.
Most wobble conditions are caused by alinment. They are made worse by bad tires and worn parts, but it's alignment.
The past post follows:
First of all let me say this: Damn all of you nice people for
wanting me to stay with aadt
Anyway, I'm not much for having a good short term memory, so bear
with me.
In a previous posting written by ???? (don't remember), they were
complaining about a shimmy in their Ram 4x4 after striking bumps in the
road.
I suggested that the front end alignment has either too little or
too much caster, thus causing a caster shimmy. He did not like my
response and changed his concern from a "shimmy" to a "bounce" (big
difference), and insisted it was the shocks. Maybe it is, I haven't
driven it. He also said the alignment "checked out". Here's the
problem:
Alignment programs (and service manuals I believe), give a wide
acceptable range for front caster on the 4x4 Rams. I believe the range
is 2 degrees to 5 degrees (if that's not correct, it's pretty close).
The problem occurs when the alignment tech (independent or dealer)
tells you that the measurements "checked out fine", just because they
were in this broad range of acceptance.
Caster readings that fall on either end of the scale are subject to
caster shimmy, even though they are "acceptable". I had to align some
30 trucks and attend a 9 hour "Dodge Ram Chassis Dynamics Diagnostics"
training session (fancy name, ehh?), before finding out that 3 degrees
to 4 degrees is the optimal caster setting for 4x4 Rams that eliminates
caster shimmy.
Below I will post what specifications I set Ram trucks to. First
I want to give a little more info on correct Ram alignments so you can
see if you had a job well done,
The eccentrics on the lower control arms ARE NOT for individual
wheel caster adjustments (even though our alignment machine says they
are). The eccentric sleeves in the upper ball joints are for adjusting
individual camber and total cross caster (difference in caster between
two front wheels). This is why replacement eccentrics are positionable
in eight different ways.
Once camber and cross caster are attained with the eccentrics, the
lower control arm eccentrics are then used to swing the caster readings
into specifications. The two eccentrics must be swung in the SAME
direction in EQUAL amounts. If they are not, it will create a setback
condition (one front wheel further forward than the other).
FYI - Comparing between the two front wheels, caster will cause a
pull to the smaller value and camber will cause a pull to the larger
value. A truck set up with caster pulling in one direction and camber
pulling in the other direction, can lead to a wandering truck; even
though it is "in specifications"!!!!!!
If the eccentrics on the lower control arms of your truck are not
pointing the same direction, the alignment was done incorrectly and the
axle was "twisted" or "forced" into position to attain the acceptable
values (seen them from the factory this way, go figure).
A correct alignment will set the truck up with a slight negative
cross caster (truck has slight pull to left) to compensate for right
hand road crown. Camber will be equal side to side slightly on the
negative side. This will help maintain acceptable camber when hauling
heavy loads, as the truck tends to lift in the front when towing.
Camber will then fall slightly positive when towing.
Just because the alignment shop says "it's in specifications", that
does not mean it is set up for proper performance and handling!!!!!!!!!
Specifications (my personal settings for every Ram I align): all specs
below are in degrees.
Left Wheel Right Wheel
Caster 3. 2 3. 5
Cross Caster -. 3
Camber -. 10 -. 10
Cross Camber 0. 0
Toe - standard specs, (maybe a little out if you tow a lot, they will
pull in as the front end lifts up).
Brent
ASE Certified
Gold Certified Chrysler tech
hello, haven't been on in awhile, been real busy with work.
had a 1st gen with 222k, dw every 8-10 thousand, bring to sams club rotate and balance, see ya in another 10k. I hear alot of guys talking about parts. I live in NY and drive some of the worst roads in the country and thats commuting to and from work. At
home 75 miles north of the city I'm always off roading, snow plowing, etc. . I've found that your much better off going through the whole truck rather than 1 thing at a time. My 1st gen I used all auto zone parts, if not available then napa, and never had a problem. I now have a 2nd gen with 282k, same thing. I guess
whatever works for ya, thats my 2 cents.
Re: change name from death wobble to Helacious harmonic wheel hop
Originally posted by jponder
We should call this the helacious harmonic wheel hop. It feels to me like the wheel starts hoping up and down and just keeps getting more and more intense. I dont think it is going side to side instead i think it is hoping up and down. I dont know because I havent seen it just felt it and it is spooky
John Ponder
Let's be specific here. The Ram has TWO different suspension maladies (maybe more). The Death Wobble is one. The haromic wheel hop is another.
The harmonic wheel hop is caused by the crappy stock shock and the HUGE imbalance between the springs of the front and rear. If you put 2K# in the bed, the harmonic will go away never to return-- then the suspension is within it's design parameters.
The death wobble is something I haven't experienced (hope I never do). I think Ted J is on the money here with his shopping cart wheel analogy. The thing to remember with caster wobble is that it doesn't take a lot of error to cause it-- a few degrees is all it takes. This is where it's nice to have the insurance that a little extra positive caster can provide. It's wise to ponder the point about a lift affecting caster.
My own personal DW theory: people smack a curb or a parking log too hard or something and the fragile stock Dodge components are moved slightly in their adjustment. It might be a part sliding in it's bushing a wee bit. It might knock a weight off the wheel and cause out-of-balance tires. It might cause the axle to shift just a little bit.
Whatever causes it, this slight deviation from ideal gets the ball rolling-- the tires will wear unevenly, the bushing and ball joints start to wear funny, etc etc. . Once the frame holes are worn, you will be throwing a LOT of parts at the front end trying to get the problem solved.
Sounds like a good reason to snug everything down with a hoss of an IR Impact gun.
HOHN
I've had shimmy before with the old twin I-beam and washboard roads.
I got the Death Wobble today at 85 or so MPH and a bump. 145,000 on the truck. I just started driving it. Been in the family since 66k, no reports of DW before.
I'm going to align it properly (per Brent) and replace worn components. Tires are 265, LR "C" and worn out, but perfectly balanced on straight rims. Brakes are new too.
This ain't no shimmy, it's a truck trying to self-destruct. :eek:
Wade done been through that... its the trac bar I assure you!
Advance Auto Parts part #DS1413 Moog lifetime warrenty track bar. Its called something else under their computer though, but that's the part #. I have had to replace one, but I went to 2. 5" lift coils also which through off my toe in and I didn't know it. At 40K on the first one Advance had no problem replacing mine under warrenty.
John Ponder
I have this same problem. At 65-70mph when i hit a slight bump I get the death wobble. I would describe it as a bucking feeling thats gets more intense unless I let off the pedal or hammer it. I read in other posts here that TTSB 18-29-97A addresses this. DC says it is a throttle linkage problem that is only for manual transmissons. Well I have an auto and still suffer from the same problem. Any help would be greatly appreciated as I dont have alot of $ right now to just start throwing parts at it. Thanxs Doodad
I've got an 04 that had one occurrance of the DW after installing a Revtek 2" leveling kit (coil spacers).
After a lot of research I think the track bar is unable to control the onset of DW because it has flexible bushings. I think the coil sprung, four link design is a ringer for DW as the Jeeps with the same basic design can have the same issues.
I think the fix is a spherical bearing'd track bar.
That's what I'm doing first. I don't trust alignment theories. Too many things in daily use put alignment out of wack... even temporarily. So you can be suseptable even when alignment is true unloaded.
The track bar needs to be a tight unit.
Chrysler designed the track bar with rubber bushings because it's the cheap way to give it the "give" it needs to handle up and down and for and aft movement during suspension travel. Remember, as the links pivot,the axle moves rearward and forward... . worse with the leveling kit.
When forces cause wobble onset, the track bar bushings simply compress and expand... unable to contain the side to side forces that only it has the job of doing... no other component holds the axle in check. . side to side. Those little bushings are being taxed to their limits. History has proven it by the number of posts I have read that claim the track bar replacement fixes it.
I would like to chime in and say ditto to caster. I once sold a set of 36inch super swamper radials to a customer with a tricked out 64 ford f-250. Death wobbles. I rebalanced his tires numerous times and told him I thought his caster angle was bad due to sagging springs. He didn't believe me. I took his tires and wheels and put them on my chevy and no death wobble. He still didn't believe me. He was not happy with his tires. I saw him about a year later and he told me he installed new front springs and his death wobble went away!
I have also know some first generation people that put air ride springs kits on and when pumped up with too much air it caused death wobble. Exessive positive caster! So if a little is good, a lot is not great! ;)
Mines Fixed!
JSmith said:
I bought a 96 CTD 4x4 ecab. Soon there after it got a violent shake to it. I replaced the track bar and that helped for a while. Then the death wobble came back and I became affraid to drive the truck because the DW would come back if I hit a pothole or ran over a bump. Two weeks ago I took the truck to a front end shop for repairs. Replace both f-hubs,rotors,f-brakes,tierod,drag link,bought dual steering stabilizer(4 months ago) and Today had front end shop install the (LukesLink). Will post results in a few days.
P. S. I emailed Chrysler about the Death Wobble and got back Corp ya da ya da ya .....
I replaced Steering Stabilizer (My Rancho 5000 was shot), Fixed trac bar with a lukes link, and even did the alignement per Brents spec. All this about 15k miles ago. No more wobble. I believe the real fix is the sterring stabilizer and the trac bar. Oo.
TED J is right on...
Ted has this one nailed down.
The vast majority of death wobble is caused by inadequate positive caster in the alignment.
Worn/imbalanced tires, worn ball joints, track bar, steering stabilizer, etc are all things that make it likely to happen, but they don't CAUSE it.
They only "cause" it in the sense that they are failing to prevent it as they would when operating normally.
The Dodge front end design is superior from a performance point, offering the very best design possible while still using a solid axle (OK, maybe a Watts setup would be better). Unfortunately, the design requres a lot of connections and parts to work. A weakness in any of these areas can cause things to go awry.
So, in order of priority, here's my recipe to wobble-proof your rig:
1) positive caster to max while still maintaining 1. 5-2 degrees caster split L/R.
2) DT PRO FAB TRACK BAR. Yes, it's expensive. Yes, it's also the only bar that fixes the fundamental flaw in the Dodge-designed bar (a vertical ball joint!). It's pricey, but if there were better on the market at anywhere near the price, I would have bought it!
3) BALANCE BEADS for your tires. Then you don't have to worry about your tires losing balance
4) T-rex steering stabilizer (using a Fox racing Shock). This is VERY expensive, but does the best job of any stabilizer around. It better for the $$!
5) Do NOT lift your truck more than just a levelling kit would.
flame away--
Justin
I'm not sure how pumping up the airbags would cause MORE positive caster. I'm picturing a foggy memory of the leaf-sprung front end on a 1st gen, and I can't see how increasing the ride height via airbags increases positive caster. To do this, the top of the axle would have to rotate toward the rear, in effect, rotating the underside of the axle toward the front of the truck.
How does airing up the bags cause this axle rotation? Moreover, when you combine the higher ride height of the airbag with the counterintuitive axle rotation, you would definitely be screwing up the U-joint pinion angle.
Could the vibration you felt be the Pinion Angle mismatch?
I just dont' see 1) how increased ride height give more positive caster, and 2) how the positive caster (if it happens) when combined with the airbags, wouldn't screw up the front pinion angle.
Justin
When you raise the truck but the axles stay on the ground, the pivot links that are connected to the frame and axle, top and bottom, rotate the axle tube counterclockwise looking at the drivers side wheel from the sde of the truck. This takes a way caster the more you rotate it.
2004 2500 4x4, QC SB SLT, HO 305/555, 48RE
Hummer Wheels W/ LT315/70R17 BFG's, Gutted Intake Tube/Silencer Ring AWOL, 5" RIP Straight Pipe 6" SS TIP, Mag-Hytec Rear Cover, K3LA Locomotive Horn
Had a Duramax
2004 DODGE PICS AND INFO
Hohn,
The first gen set up I am referring to had the air bags located on a bracket that went between the rear of the springs and the frame. Increasing air pressure moved the rear of the spring away from the frame increasing travel and ride height and positive caster. Pinion angle was also changed but wasn't a big problem due to a cv joint on the driveline. If I remember right there was a similar set up for the rear of the vehicle. :)
See Technical Service Bulletin 19-05-06. describe the procedure to fix this. I have done this to many trucks and not had the problem come back. If everything is tight on the front end the auxialry sreering damper fixes the wobble.
https://www.turbodieselregister.com/forums/showthread.php?p=1066735
Ted Constantine said:
Hey Guys,
Death Wobble is a VERY common problem with lifted Jeeps like Grands, Cherokees, and coil sprung Wranglers. Death Wobble on trucks with a coil sprung front is very easily fixed. It has everything to do with the Trac-Bar or warn suspension bushings. Check your tracbar either the bushings are warn or the bolts are not tight. you want to get that bolt as tight as you can and/or press in new bushings. it has nothing to with tires/brakes/shocks. another big issue is the steering stabilizer. all stock stabilizers are weak. if you replace that with a aftermarket one you will be much happier. when you replace the shocks or swaybar link bushings you are just able to control the problem easier but it does not fix the initial problem. Hope this helps, it always does on Jeeps.
The best permanent fix for the death wobble after making sure your front end is tight and the bushings are good is to take the truck to an alignment shop that knows what they are doing. Dodge put way too little caster in the front end from the factory. Have them increase the faster to 2. 5-3 degrees. I did this to mine after replacing the loose parts and the truck is still solid as a rock after 60k miles. Best steering mod you can do.
