Engine/Transmission (1998.5 - 2002) Replacement VP44
Engine/Transmission (1998.5 - 2002) Dual disc clutch release issue
2nd Gen Non-Engine/Transmission HD Steering question?
Blue Chip makes serious claims to have the best VP44. Chip also provides top notch tech support and customer service.
Midwest Fuel Injection has the cheapest VP44 (that I know of).
What do you mean by "upgrade"?
A hot rod VP44 uses a combination of parts to allow it to deliver more fuel. A Special X VP44 uses parts that give it more timing advance. Your Smarty already has that covered.
Another vote for Blue Chip Diesel!!! I blew my first one up with an aggressive tuner with the pump tapped and went with a top-of-the-line Special 'X' with NEW electronics that don't have any heat cycles.
RClark, if you’re looking for top notch rebuilt go with Blue Chip, however, there is a shop in San Bernardino that is Bosch factory auth. that keeps rebuilt VP44’s on the shelf.
gregg
There is a closer one to you BECS adp fuel injection they have always delivered for me but IIRC in whittier,there used to be one around the ports but I never remember the name
