Barry, if you are just looking for extra miles and improved traction in dry and rainy conditions, this is what I would recommend for your Michelins:
It shows a deeper, slightly wider groove with small "sipe grooves" at the edge of the groove. I used a 3/32" blade, but I would actually recommend a 1/32" blade or even just siping them. The next picture shows a close-up.
For the Michelin, I would pull 4/32" out of all of the grooves, and make each groove 1-2/32" wider than stock. Since your groover can also sipe, I would sipe the 3 center ribs.
Now, if you were looking for more traction, this would be the next step up:
(Keep in mind that I would cut the grooves deeper on every option I'm showing. I just didn't do it here. )
Next, for even more traction, I took the last pattern and added narrower grooves between the wider grooves:
Pretty simple.
I thought I was being a genius with this pattern:
But if you look at the top of the rubber blocks, there is only a narrow amount of rubber, nothing to keep it in place, so it is very squirmy. A narrower blade would have better results here.
Next is a simple pattern that I wouldn't recommend, unless you like the sound of chainsaws. Very simple, but the perpendicular edges will be loud and annoying:
Another simple pattern with only narrow grooves:
Next is a Bridgestone (very similar to Michelin design). I used a 1/32" blade, cut a diagonal in the center rib and siped the ribs next to the center rib. This netted a very impressive gain in wet traction with no increase in noise:
And here is just me deepening the traction grooves on a steer tire. This tire is about 16" wide and terrible in rain, mud, snow. You may be able to tell that I also siped this tire. I followed the existing traction groove and used it as a template and cut it down to 2/32" less than the depth of the circumferential grooves
I don't know how deep you can go with the Continentals, but I would think you could safely go 3/32" deeper than original. Try 2/32" first and probe the groove with a pick or something similar. You can always go deeper later. I would widen the circ. grooves, and on the "female puzzle pieces" only go as wide as the original grooves. You don't need to go wide there. I would also sipe, no matter what. Measure the new depth, make your siping blade about 2/32" shallower than that and sipe away! I assume you know that with your tool, you can just turn your grooving blade upside down and use it to sipe?
