Replacing rear wheel brake cylinders
Internal Voltage Regulator
SMalafy
Does anyone know what Ford type rear wheel brake cylinders which are bigger that you can use to replace stock ones in my 2001. I used them before in my 95 12 valve but forgot the # or Ford type model they were for ?
I used Chevrolet/GMC 1 ton brake cylinders, if I recall correctly. They may have been 1-1/2 ton cylinders. The brakes are made by Delco, so there is a lot of interchangeability. The result was better braking. I kept expecting rear wheel lockup or weirdness on wet pavement, but it never happened. As always, braking was better with at least a light load on board.
If I was doing it again, I would use cylinders that Iron Duke linked.
On my 98 I did the 1 3/16" wheel cylinders and also removed the proportioning valve. There is an OE replacement hose for the valve. Big improvement!
