A friend has a 98 24v with 15 psi at the lift pump. It set the following codes P1689-no communication between ecm and injection pump.
P1693-DTC detected in companion Module A fault has been generated in the companion engine control module.
I took the truck to a local diesel shop which I thought I trusted but now am a bit skeptcal. They said yeah the pump is definately shot but the computer may also be shot-theyre not sure. I'm starting to believe the pump may not be bad so I'm going to take it to another shop and see what they think.
If this pump is bad then why didn't I get a P0216 code?(Inj pump) Also, how hard are these pumps to change-they look very simple. I need good advice here from some experts!!PLEASE
