Vaughn MacKenzie
Last time I was messing around under the hood of my '98 I got to thinking it would be nice to reroute the heater lines so they're under the exhaust manifold like the 24-valve trucks. It would make injector swaps a little easier, plus to me it looks kinda tacky to have them mounted above the manifold. It would definitely make it look cleaner.
Routing would be a little tricky but I think it's doable. The take-off and return points are different on the 12-valve so it's not as simple as swapping out for 24-valve heater tubes. But I think using heater tubes off a 24V and patching in pieces of rubber hose as needed would do the trick, as long as it doesn't look tacky or redneck engineered in the end :-laf
Anyone else consider doing this? When I tear my truck apart for a manifold & turbo upgrade later this year I might give it a whirl.
Vaughn
Vaughn
