Rock Chips
Relax and Chill out
Running Boards
I followed the directions that it came with if I did it wrong I wish I new how to do it write
My reply to you just went into cyberspace so will try again. You can call customer support and they will walk you through each step. Instead of using the rubber gloves, try using the "plastic scrapper". It can be used for just one rock chip or a lot of them. It allows the paint to.be applied smoothly to each chip. If you have a deep chip, down to bare metal, try to just fill the hole part way and then wait a couple of minutes and fill it up, take the scrapper and immediately slide it over that hole. Most people get it messed up when they apply the liquid to remove excess paint. They apply it to soon or to late. The main reason people use this product is cost. Pay X number of $ each Spring to fix your rig or pay less for this product. Nice thing is that you can apply this to your vehicle any time you get a chip or every Spring.
Your other option is to have a detailer or body shop cover the front end and hood with different types of thin, flexible and removable plastic which will not allow paint to be chipped. You can also have this applied to your rocker panels. Most of these products carry a 5 year warranty.
