Bow66tie said:
I thought I read in our newest edition of TDR that you'd have to have at least a 6 degree change in the timing to notice any difference in mileage. I have thought long and hard on this accessory, but after reading the article I think I'll have save my $60. 00 for something else and pass on this one.
Michael
I emailed Robert Patton about that article, but got no answer, except from his secretary.
COmbustion has a fixed time delay of a few microseconds, and at 750 rpm one degree of timing will produce three times the interval (microseconds) that it does at 2250 rpm. SO, if you can use 6 degrees max on top of the factory timing advance (without busting the head gasket, as described in the article), then at idle it has to be dialed back to more like 1. 5-2 degrees.
Since the TST uses the signals from the stock crank/cam sensors, rather than re-program the ECM, keep in mind that they have to delay the signals from the sensors to the ECM by 2 full engine revolutions (for a 4-stroke engine, or at least one rev, if you cross the signals to the injectors), minus a few degrees (3 or 6 or 9 degrees). There is no way to electronically advance timing, just to delay it. So with that box on, you will have to crank longer by 2 turns, and the response will be delayed by two turns, minus whatever degrees of "advance", which can make the engine slightly prone to surging on cruise control, etc.
If you move the sensors (advance timing) physicaly, and then use an rpm and load-proportional time delay, then you get better response. (That's how the ECM does it, and a downloader can take advantage of that, but that may cost you your warranty)
I agree that advancing a fixed amount has the largest benefits at low to mid rpm, and the gains decrease at higher rpm, but most people do not care about improving their 3000 rpm efiiciency, but rather idle to 2000 rpm.
Also, the efficiency (and power) vs. timing changes, is not linear, but rather it follows a parabolic curve. This means that if your factory timing at 1800 rpm is delayed by 3 or 4 degrees from the theoretical peak (most efficient timing point) due to emissions, it is not necessary to bring it back the full 3 or 4 degrees. Why? Because the loss is not linear, and there is hardly any measurable loss for the first degree (1% or less) but then for every successive degree of retard it gets bigger. So when you advance a retarded timing engine, the first degree of advance will give the biggest gain (lets say from 4 to 3 degrees may give you 3% improvement, the next degree from 3 to 2, a 2% improvement, the next one is closer to 1. 5%, and the final degree only about 0. 7%).
So if you want to throw good money chasing the last 1-2 degrees, it does not pay as much as the first 1-2 degrees did. Also, once you cross past that peak, your efficiency will drop (and stresses rise) slowly for the first degree, and then more and more rapidly for every successive degreee of overadvanced timing. (the law of diminishing returns)
On top of that, cetane and outside temperature makes that theoretical peak a "moving target", which means that it's best to err on the side of being 1-2 degrees retarded, that 1-2 degrees over-advanced (both of which lose power, but one damages your engine as well)
So if a fixed timing advance of 2 degrees will give you a one mpg real-world gain, at $3/gallon, improving from 16 to 17 mpg will save you $551 over 50K miles, from a sensor that costs about $70.
A very sophisticated box or downloader, may double those savings, but you will have to pay for those savings upfront in the form of an extra $600 or so, and the potential for more problems, and warranty denial.
