For anyone intrested, I'm putting together a roll cage the will fit out trucks. The main hoop will be formed and the door bars and rear stabalizers will have the form in them. Just like any roll cage, holes will have to be cut in the floor board and the frame will have to be drilled. The cage will have to be welded by a professional welder, certified, to meet rules. You will need a small grinder to fit the joints. If you look at the regular cab, the point we need to install the main hoop is right on top of the body mount. That is the hard point to work. As per NHRA rules, the cage, at all points have to be welded to frame. That is critical. Tech will get you. I hae a plate made for that spot
I made the cage for Darren's truck and Brian said it was good, with 1 changes, so that's what I'm going with. Darren is good to 10 sec's.
I have a ball park price + shipping but as most of you know, steel prices have gone out of sight. Call or e-mail if you are intrested and I'll let you know what it is now. The no is 770-365-2713 or -- email address removed --. I'm working out of Garmon Diesel's shop for the present so I could be reached their also. 770-898-8585.
Let me know if I can help. Thanks
. . Preston. .
. . Preston. .
