I believe I posted the response from Cummins on the correct filter to use on the 24V engine. I'm on my second LF3552 oil filter and have not had any problem. I ordered the LF3894 Strata-pore from Geno's garage and those go on at the next oil change and everyone after that. The LF3885 is the regular oil filter that can be used on the 24V engine. I have the response at home and will post it tonight.
John
1999 Dodge Ram 3500 Quad Cab 5 spd, 4:10 LSD rear; Mag-Hytec diff. cover; Manual transmission filter kit; Geno's EZ Drain oil pan plug; Speedliner spray in bed-liner; Amsoil foam air filter; Smittybuilt step rails; US Gear EGT and Boost gauges in a twin A-pillar mount. Towing a 31 ft. NOMAD single slideout TT.
Rammin' and Runnin' the roads
John
