i am in the process of replacing the rotors and hubs on my truck. i came across a 5. 0 mm spacer/shim on the right side of my truck but none on the drivers side. this spacer mounts over the studs before the wheel. should there be a second one on the drivers side? leave it off?? any thoughts?? also any place to buy the flange bolts that mounts the hub? dealer wants $9. 25 each! is there an internet site that has the parts look up. some agriculture companies have this. wondered if dodge does.
thanks!!!!
Duane
thanks!!!!
Duane
