The manual I own is for 2x4. The truck is on the stands and i am unsure about removing the rotors. Do I have to remove the selector switch? What kind of inards will fall/fly out? Is there a nut like the rear shaft? etc. etc.
Steering shaft
Is replacing the seal on the input shaft necessary? It also appears the shaft I received from Borgeson appears to be too short. It is a full inch short of the original shaft coupler when i put it up next to it. Does the stering shaft extend and retract above the rag joint?
It is a 1993 350
Thanks in advance
Steering shaft
It is a 1993 350
Thanks in advance
