BK
you can "suck" out the fluid if you want too.
Sky, your not off base,,,,
just to point something out. .
in my earlier days I used to work on toyota 4x4 with straight axles front and back.
They had a removable 3rd member like a ford 9" rear.
there were no covers to remove.
Nicely enough toyota put a drain plug in the rear. But if some one demolished the lower drain plug ... I used to use a diff oil gun to remove and add the new fluid (it was easier to pump it in with the oil gun -looks like a big grease gun but with a 1/4 hose on it- then trying to squirt it in from the bottle with they way the yota's axles were).
So you dont have to remove the covers if you dont mind sucking the fluid out with one of these $40 guns... powered by armstrong push pull and dont try it in the winter...
It's just not as complete as popping the cover or getting a maghytech cover
