AMassaro said:Has anyone used the TST box by itself and if so, what were the results? How is the drivability and performance?
T.
Tomeygun said:...
But the performance was always good. Netted a 396 hp dyno run with TST alone (and thats on a 199hp stock to the wheels truck)
Buffalo said:The dyno runs, I've seen, on 305 HP trucks showed 265 RWHP, pretty regularly.
I wonder if that truck was a Standard Output engine. That would make more sence.
Joe F. (Buffalo)
JasonCzerak said:DOH! your right, tommy's is a SO truck. that does make more sence.
So, 305hp trucks, putting out 265RWHP, That's like a 14% drive train loss. Now this doesen't sound right either being that low could it?
Tomeygun said:You do know "SO" stands for Super Output, right?
hahahhaa
JasonCzerak said:I was thinking it was Slow output.
ROBERTMACDONALD said:well i have a 04. 5 325/600 that only ran 366 on 9/9 , and when we turned the box off the truck ran only 220 , that seems darn low , since that run on the dyno i ve put a new fuel filter on it , had all sensors checked out , i have 6900 psi at a idle and wot is 23200, and i had a 150 fass hooked up during those dyno numbers , i hope when i get back to the dyno its alot better , i was hoping to see atleast 265 - 275 with the box off ? i have a 48 re with valve body and 411 gears with 35" tires , any help out there ?
Tomeygun said:OUCH! slow until Don and Mark and John messed with it!
Darn them! :-laf
