I have an 04. 5. The truck was ordered and I took delivery 5 or 6 weeks ago. I have had significant problems with the truck already and I'm beginning to think something is up with this truck. It looks like someone took it for a joy ride in saltwater before it was shipped to the dealer. The trans is solid rust as are the front knuckles drive shafts and many of the fasteners under the truck. The engine block has a significant amount of rust on it as well. Even the aluminum parts such as the bell housing and transfer case have large areas of corrosion on them. I've looked at the undercarriage of several other trucks that are older than mine and they have no where near the same level of corrosion. Now I'm starting to hear a squealing noise from the front end when I'm cornering, sounds just like bad wheel bearings. The truck has been in the shop for nine days total since I took delivery. Eight of them having a leaky transmission input shaft seal replaced. Dodge even treated me to a dent in the truck right from the factory. I have tried to talk to Dodge about it but they tell me it's up to the dealer that sold it to me to put me in touch with the local Dodge rep. Of course the dealer is ignoring me and Dodge isn't returning calls either. I even had to finish the job for the mechanic. He forgot to reinstall the bracket that holds the wiring harness along the top of the trans. They put so many scratches on my dash taking it apart the first time I decided to fix it myself. So out came the center console, shift levers and rubber boot on the floor so I could reinstall the bracket.
Well I got carried away here. The question I wanted to ask was if anyone else got a truck delivered to them rusty like mine?
Gino
Gino
