Good morning boys and girls
riddle me this
with the truck in sig. - new vp44 13k ago - off warranty now :{ .
For the last week or so I've been getting HIGH fuel press readings. pressure is on an autometer z series (0-15lbs) plumbed directly to the vp with one of Rip's kits. Sitting at a light at idle the pressure used to be 13. 5 to 14. 5 lbs. now it will slowly creep up over 15 to say 16 or 16. 5. At this point it was runnnig fine and not showing any codes in odo display.
However, tonight I had a little stumble at cold start and pressure readings were WAY high while cruising at 35mph in town. WAY high means needle was pointing to 6 o'clock. still runs fine but takes a longer crank on some warm starts.
What gives? am I losing another vp44. What would give high pressure readings? bad gauge or some restriction at the vp? Is there some sort of pressure blow-off that isn't opening? An intermittently restricted return line?
any thoughts would help
Thanks - I can't afford this right now
riddle me this
