Tuesdak
I don't have to know what is a good oil or bad oil. I just have to read the amsoil website and catch up on all their videos.
And as for "knowing".... It is all pretty much opinion. Just because you like your UOA analysis from one oil, doesn't mean it is really any better than another. I am on my third crankcase of 100% (no added oil from other brands) Kendall Super D XA 15w 40. I liked what I saw from the KSDXA in terms of wear metals on my UOA. I did not like what I saw in terms of fuel dilution. But even though the viscosity was coming closer to a 10w 30, the wear netals tested low. I plan on testing again this fall. (Same oil)
Don't switch oil brands or types if you want to do UOA. For example switching to synthetic can shock some copper off the oil cooler and spike your numbers. I used to run what was on sale and it changed each month. Doing 4+ oil changes a month the variance made the trends difficult to read. There is just enough difference between oils, but, major difference to synthetic. Regardless a pending engine failure stood out in the mixed brand samples from a scuffed piston. I didn't say "better" oil: I said keeping the variables the same to better watch trends in UOA.
Fuel dilution is not the fault of oil. It's something like too much idle time, fuel leak into the crankcase, bad injector, stuck thermostat, short trips not getting the oil hot, excessive regen times, high biodiesel % in fuel...
