okay, so long story short;im navy and in 13 months ill be state side after deplyoment. will need a truck truck not a racer or puller need to be towing yj on 1 tons on 40's. and other 4x4 rigs as well as horses and cows and using the truck to haul logs, hay and misc heavy euipment. truck will see mountain driving as well seeing mud and rocky terrian. not purposly going mudding or offroading just the nature of living in the hills of the northwest. so a performance truck is not what i want. all i want is to make the truck breath and perform better. so intake exhuast and deletes of any emissions since where i will be living and where i live now dont do emmissions anyways. and a programmer to tie it all together but not set on high setting. i would like the g56 manual/nv5600 depending on witch engine i end up with. im leaning towards 6.7 becuase one its the current cummins engine, and during deployment i can pre order the g56 supporting mods i.e gridle,upgraded single fly wheel clutch, coolers ect. so my main question and i been trying to search and home work. but am i correct on problems/solutions for the cummins/transmissions? or have a been scared becuase of reading false imformation and hopefully this forum is legit?
03-04 cr/nv5600= valve seats tends to drop. nv5600 requires clutch once modding. mechanical waste gate so better mpgs, overall great truck
04.5-07 5.9 cr= injectors issues and melting of pistons; solution is upgraded filtrations via fass,airdog ect. 05 came in g56 6spd(i know the transmission dont need to ask questions ).
07.5-now 6.7 cr?? did something changed in 2010? from what i read head gaskets go easy but studs and gasket is a fix. the vvt goes out quicker or as quick as the others due to the emissions stuff. as well as mpgs goes down as well. but the 6.7 came with the 03-04 pistons and injectors that are more durable. unless something changed if you take care of the emission stuff on the 6.7 they are awsome?? just trying to get real world problems and solutions before buying my first cummins. im really sorry but i been looking at forums and magazine and cant seem to get any solid answers
