Hello, Just picked up my 1993 350, and of course there are somethings wrong but not enough to call off the deal. One problem that I need to fix is the drivers seat which does not move.
Far as moving it forward or back, I have looked at the mechinizm (spelling??) and can see it will release the tooth on the left side, but the right side remains engaged. I moved the right side with a screw drive and the seat will move. Now I do not see anthing that has broken off, so I am not sure how this should work? Maybe someone could look at there seat and see if there is linkage that couples the two sides together, or figure out whats happening. I am driveing the truck to NYS from flordia and do not have all my tools else I would have taken the seat out.
The other seat problem is reclining. full up is ok, but if you recline it will sort of lock in but much pressure on the back and seat will continue to recline. I suspect a worn pin, but this does not look like it is easy to fix as the assembly is rivited togther far as I can tell.
advice?
Greg
advice?
Greg
