Matt42
Has anyone ever separated the seat back from the seat cushion on a 2 door club cab? This should apply to any cab that has the fold down center seat cushion with the pop open center console/seat setup.
The assembly uses two different style 6 mm phillips shoulder bolts as hinge pivots. The passenger side comes apart easily. The driver side bolt comes out but the hinge assembly remains engaged. I have tried gently using pry bars but without success. (Yes, anything can be taken apart if putting it back together is not part of the plan.)
This is what the factory TSM has to say about removing the center seat assembly, which is not useful for taking the assembly apart:
I have already removed the center seat assembly. It's heavy and awkward and residing on the back seat for the time being. I will eventually need to remove the console lid for re-covering, and that is in the next paragraph in the TSM. But right now, I want to separate the seat back from the cushion so I can get them easily out of the cab to work on them. Many thanks in advance.
