Shift Knob
Throttle Linkage
When to change to Delvac 1
Shelby,
Yes, I am thinking about putting together another kit. I am currently waiting for all the pieces to come in as I had to order some of them. It is not going to be cheap, it looks like around $200ish for everything, including the shifter knob, adapter bushing and everything else needed for both the full function two low kit and to control the exhaust brake. By the way, on my 97 five speed, the threads on the shifter are M10x1. 5 and the threads on the fuller knob are 1/2"NC threads. I have mounted the knob on my truck and it seems to be a little high for my taste, so I might shorten the shift rod to get it back to the orginal height. Also, it seems to resignate the noises from the shift link lever. Don't know what I need to do to fix it. Maybe just a fiber washer. By the way, we are heading out to Bend this weekend for some RV'ing at Sundance Meadows. Maybe we will see you on the road. Bob V.
Bob,
I think $200 is a reasonable amount. It is a 3 for one deal: You get a custom shift knob, the two low kit and a shifter mounted e-brake switch for less than the other options available for the two low and shifter mounted e-brake, not to mention the cool knob.
I was wondering about the height, what does it sit, about 2 inches higher?
Maybe I will see you down here this weekend.
Shelby
