Engine/Transmission (1994 - 1998) Short blocks??
Engine/Transmission (1994 - 1998) rebuilt 5sp , lost 5th?
I'm looking at a 1998 CTD engine w/ manual trans for a conversion in which the ad claimed the engine was totally rebuilt, well after talking to the guy I discovered that it just got a new short block.
The story goes, he installed a brand "X" oil filter (first time cummins owner) and after some time the engine basically chewed itself up on the inside. Supposedly (have not seen paper work yet) it was towed into a Dodge dealer in which they installed a new short block and used the original parts, like cylinder head and so forth.
I have been told by other users on this web site to use the manual trans engines because they had higher Hp/TQ ratings than the auto's.
Well my question is this, besides calling the dealer when they open to see if the part numbers are different, does anybody know if their is a difference between the automatic and manual trans short blocks? :confused:
marty
There a few differences (pumps, heads, turbos, etc. ) between the different years but the bottom ends are all the same.
Nathan
I think that is correct. The 24 valve engine uses an electric pump so there is no cam lobe to drive a machanical pump like on the 12 valve engine.
215 hp engines (5 speed trans) used different pistons (top ring is farther down) and a different camshaft that is polished and shot peened behind the first bearing journal so it won't tend to break at higher rpm.
