The 3. 42 gears are there to squeeze a fractional MPG gain for the government's CAFE requirements, not to enhance the towing capabilities or experience. They will effectively render 6th gear useless for towing, unlike the 4. 10s. Not a good match for towing with double overdrive automatics.
Rusty
Rusty
What are you basing this on the gear ration in the 68RFE of the 2007. 5 to the 2012 MY trucks or the gear ratios of the 2013 MY trucks in the transmission. I have not seen these ratios published yet but I believe Ram has provided design improvements of the 2013 trucks over the other MY trucks. Such as and I quote; “For 2013, all Ram Heavy Duty diesels benefit from an all-new cooling system. A high-efficiency fan, dual radiators, dual transmission coolers and low-slung charge air cooler afford 25 percent more heat-rejection capacity. Lower operating temperatures deliver improved performance, durability and lower operating costs. Cummins Turbo Diesel-equipped Ram trucks also provide best-in-class 15,000-mile oil change intervals. ” From TDR press release.
I am a retired engineer from Cat and I have learned over the years not to second guess what other engineers have designed for different products. We all have different design parameters to work with and these change with every new model design that the engineer works on. Functional specs are always changing by the marketing department At least at CAT and this is what we always design to.
Jim W.
