Side Marker Blinkers
Removable Auxillary Fuel Tank
Anyone with DT dual shock mount and Links?
Anyone done side clearance blinkers? Autobarn has the arrow stick ons for the mirrors but they do not show how the
wiring is attached to the lights. On the same note which wires would be the best to tie into on a 97.
If you go to some of the websites for the pocket rockets they have many diferent styles of lights, as far as wiring a buddy of mine did it to his Honda, we just spliced into his front turn signals. Works great.
Tom
Are you looking for side marker's or side turn indicator's?
You'll need two relay's (per side) if you want both.
Upper left wiring is Running Light's.
First time attaching a pic here... hope this works. It's a couple of photos of my mirror mounted signals. I used lights that match the dually fender assemblies, and cut a piece of one inch aluminum angle as a mount. Hooked the wires into the harness under the dash. Hardest part is getting wiring through mirror bracket. Hope this helps!
heres what I did. I used a LED Light from a Pilot truck stop and ran a wire from the front turn signal to the light and grounded to the body.
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=5697&width=2/src img>
Hella DuraLED Side Marker's...
Front...
Rear...
Side Profile...
Front, Night...
Rear, Night...
