first, is it worth it? entirely up to you. doesn't add any power by most people's accounts.
if you like the whine, then it helps removing it.
as far as getting the snap ring out, there is a slight taper at the ends of the ring. if you use a smaller flat blade screwdriver (1/4"), wedge it into the edge of the ring and then twist the screwdriver till the ring starts to lift up. once you have it lifted up enough, take a very small screwdriver (like 1/8" blade) and put it between the snap ring and the slot. once you get the small screwdriver under the ring, you should be able to keep working it while pulling "out" on the larger screwdriver, until you get about half of the ring out. after that, you can just pull on it with your hand while working the small screwdriver behind the ring.
this is what worked for me.
good luck!
Jim
