to get your silence ring out,pull the hose off the turbo that comes from the air filter box. you'l see a snap ring-it doesn't have holes in it like you might expect. use a small screwdriver and lift one end out and work it around till it falls out then just pull the piece it holds in out, it doesn't amount to much but make quite a bit of difference-love that whistle.
