I have a DTT in the truck.
As far as the better clutch material, I have no idea. I have not been able to slip my TC under and circumstances.
Now, with all that said. I think the real differences in the TCs are in the fluid coupling. With my TC, it is much tighter than my buddies ATS. He has to get an early lockup or I will flat out run him. When my TC locks, it is not harsh or abusive. With his, it is a sudden drop in RPMs. Now he is able to get the RPMs up quicker. Sure sounds impressive! :-laf
One note, he shifts locked to lock under throttle. The shifts are smoother than at 1/2- 3/4 throttle. We have come to the conclusion that the TC slips a little and results in a smoother shift. If I shifted my truck lock to lock without billet shafts, there would be pieces on the floor. So maybe the fluid acts as a spacer until it's forced out and full lockup occurs? But no matter the design, the TC is mathematically the strongest clutch in the trans.
If you stacked 100 clutches on top of each other and applied the force to a 12" circle and did the same with one clutch fiber and applied the same force to both, witch would holder better? From my racing days, I have my own opinion.
BTW, the 5 disc unit that was referred to earlier is a Mercedes design I believe. It's in a car and has much less power, torque and weight. It's not even a reasonable comparison. Besides, smooth shifts are key, not lockup strength.
I have heard more about TC carnage with the triple disc convertor, especially in regards to flexplates. There is simply more mass there. And it's spinning along at a pretty good clip. So, if it gets loose, it may do more damage. I don't know.
Have fun with whatever choice you make!!
Dave
Dave
