OK, this is the second time I've written this today, the computer ate the first attempt.
I loved Steve S. design on the traction bars and started to make a set for myself.
Early on in the measuring stage, it became apperent that a box I have mounted on the outboard right frame rail would be in the way for the bars. (this box is the power box for my lower strobe lights and can't be readly moved) So, I did what any lazy american would do, I just built one bar...
... . Now that you all have gotten back up off the floor from laughing so hard, here's what I did.
The bar itself is 1. 09" ID rollbar material
with a smaller piece inside for a double wall effect. aprox. 30" long. 3/4" HEIM joints are used at each end.
The rear bracket is just like what Steve has on his axle tubes, but mine is welded to the top of the banjo housing. Now don't get all upset, the center section is malable steel (cast steel) NOT cast iron. Welding is straight forward with normal prep.
The front bracket/stiffener is a piece of 1/4" inch frame rail cut to a L. (4" on the face and 2. 5" on the bottom) and aprox. 15" long. To this stiffener I welded two more brackets just like the ones on the housing. I then bolted this assembly to the crossmember in front of the rear axle.
The bar is aprox. 8" above and 1. 5" to the left of the driveshaft.
Results. After two weeks of flogging (and two tank fulls of fuel to prove it), I can find no adverse effects to the axle articulation or ride quality.
This posting, is in no way intended to slam Steve S. or anybody else who is using two traction bars, it's just my own way of doing something, and it appears that for once, it works !!!
Steve S. was right on about no wheel hop or axle wrap. YEEEEEE, HAAAAAA !!!!!!!!!!
My material costs were under $35.
My fabrication and mounting time was about 5 hours.
My play time is endless !!!!!!!!!!!!!!!!
I have taken the vehicle off road (slowly) to check for binding and or breaking, and
so far, everything is looking great.
I will admit that if I'd lift the vehicle or do serious offroading, I'd reevaluate the system. But for my kind of driving, it's working GREAT !!
I'm sure I'll get hammered on this one, so commence with the hammering..... : ),
97 2500, extcab, 4x4. BFG 285/85/16 AT, "warmed over" pump, JRE Stage III plate, AFC spring kit, BD gov. spring seats only, 370 injectors, K&N, 4" Edwards Exhaust with Dynomax straight through racing muffler & 5"tip, (Cat got "lost"), EGT, boost, oil & transmission temp. gages, Low Stall torque conv. & BD valve body, silencer ring "exiled", Grover Emergency air horn and a multitude of strobe lights and switches (Vol. firefighter)
