If you go with the Torklift frame mounted brackets for the front, make sure they are manufactured (they will have a manufacture date label on the box) after 1/6/03. If they were manufactured before that date, you will have to drill two holes in your frame rail. Torklift changed the design later without changing the part number. The later ones dont require any drilling.
For the rear, the Torklifts didn't fit my 03' at all. The holes were in the wrong location and the flanges on their brackets didn't have the correct spacing as our frame rails. I called them and they couldn't help. I ended up installing the chrome rear bumper pins that everyone uses and took the Torklifts back.
Hope this helps.
