Finally getting around to the camper
What sort of cleaner/lube should I use on the rubber gasket around the slide out? How often should I lube this? Just looking to see what you're using, any recommendations, etc. before I walk into the RV dealer not having much of a clue :{ aka $$$$ I did a search on the lube for the rack & pinion, so I'm set there... . thanks
I'm set with maintaining the roof as well... . BUT any advice is more than welcome
Thanks in advance.
