can i slide the stock plate a little forward, for a little more power, will it increase egt's, or should i get gauges first?
thanx
dt
thanx
dt
Reb. B said:no, it won't increase egt's, it won't really do anything.
Reb. B said:no, it won't increase egt's, it won't really do anything. Cut a pie shape out of the center like a 10 plate and put it in the middle and it will be perfect.
DieselTorque said:can i slide the stock plate a little forward, for a little more power, will it increase egt's, or should i get gauges first?
thanx
dt![]()
DBCooper said:I could hit 1350 degrees very easily with my stock plate slide forward. It would be foolish to slide it much without guages.
Bhale said:Yes, slide the AFC housing all the way forward
Brian
Johnstra said:Mine doesn't smoke like it should either. Some people can get more fuel than others with the stock plate and AFC housing forward. I think my AFC hangs up a little bit off the line.
-john
