Maybe just your grids cycling.
Billvo,
Mine did this about a year ago. Cleaned the K&N air filter and it went away.
had same problem, on mine after having to change out apps ( due to dead pettel problem) , i installed a new apps from mopar & the surging started, could take smarty off truck, & would help but not fix problem, i then got wilson apps from timbo, installed it & adj same, no more surging, smarty back on max- all ok
They cancel out after 15 mph so that is definately not it.
My AFE air filter is clean so this is not the problem either
I am starting to lean towards this as mine has never been replaced yet. It is not as bad when ambient temps are warmer but below 40 it gets worse on mine.
Not all that uncommon a problem - just doesn't usually surface until temps get low, and seems aggravated if pulling a load or grade.
QUOTE]
Mine is worse running steady unloaded, once loaded down by a hill or an actual load it is smooth as can be. Just a bad lope/surge at 1500-1700 rpms only, no matter what gear, strictly rpm related.
QUOTE]
Mine was bad enough when towing our 5er in cold temps, that I finally installed the IAT resistor "cure" some here on TDR have used to fool the engine control electronics into thinking it's warmer than it really is - seemed to help, but again, not enough cold weather driving to really know for sure.
I've driven the truck by itself in the mountains around here and in the flats under all normal speed and road conditions, at zero degree temps - and no observable problems - so hope mine is "cured"...
