I disagree with a slipping DMF as the cause on this application.
1997 and older Ford 7.3L did have an internal torque limiting friction clutch in its Valeo DMF.
The G56 LuK DMF does have a spring damper system but it does not include the torque limiting friction clutch feature.
GCroyle, thank you for the information you provided. I see your point here and I agree that it is not designed to slip. But, is it possible for the DMF to slip under certain failing conditions even though it is not designed to do so?
The reason I ask is because I was involved in helping to change out a clutch that was reported to be slipping in higher gears under a load (several times). After removal and inspection I found that the clutch facings, the pressure plate face, and the flywheel face showed no indication of excessive heat. The clutch disk had only minor wear on the surface. This is why I was thinking that the DMF had failed (slipped). Unfortunately, there no way to inspect the DMF. Everything was put back together with new parts including a single mass flywheel.
So, it just seems strange to me to have a slipping clutch failure at such low miles. I have had personal experience with two other failing DMF's, one in a 2006 Dodge Cummins at 155,000 miles, and another in a VW Beetle TDI at about 95,000 miles. Neither had a clutch slippage problem and both had vibration issues. Upon disassembly, it was obvious that the DMF had failed on both vehicles.
The 2006 Dodge Cummins clutch was replaced with a Southbend organic single disc clutch kit (good to 900 lb/ft torque), a single mass flywheel, and a hydraulic kit. The clutch operates smoothly, but it does require a bit more pedal effort.
As far as being noisier than the clutch with the DMF - maybe; it was hard to tell.
- John
