I have an 1/8 to 1/4 turn of play in the steering wheel. I have checked the joints at the tie rods and draglink ends ect. They are all good. The track bar is slightly loose and is getting a Lukes Link soon. While checking the front end I noticed that the steering box seemed loose. A closer inspection revealed that although it isn't leaking, the pitman shaft actually moves side to side in the steering box. It doesn't show any other signs of damage or make any noise. It actually seems to work fine. I was doing some research and came across the BD Steering box stabilizer. I appears that it might help, however the repair seems to address frame flex. If I need a new steering box where should I get it from. The front end of the truck is all original at 165,000 miles. (Ball joints, tie rods, ect. ) Has 33x12. 50 mud tires on it and has had oversize tires since 94,000 miles. Thanks for your help.
