I have been analyzing the PressurePro. They only transmit when moving, however you can put a magnet near the sensor and it will come on for 60 seconds.
I had not thought about how to check the sensor ie have to move the RV to check the pressures. However with the magnet approach you could get each sensor to activate and read it as a perflight check prior to actually pulling out.
My next step is going to my local tire shop and find out about valve extenders. PressurePro gave me the number at Haltec. I called them and they sent me a email of extenders they have. I want to compare those with my local tire shop.
Once I get the extenders figuered out then I'll go from there. It is a pain to air up the duallies, and this may be the reason to make it easier.
I'll report back on what I find out about the extenders.
I'm leaning toward PressurePro because if they have this for semi's and the beating they take, and the sensor is good for 100', and the sensor is rebuildable for the new battery at a reduced cost (3 years and has a battery low display on the master display), the ease of installation, the clarity of the display, the sensors are 10 psi - 150 psi which should cover most applications, multiple reports of "no" problems from full timers.
The only negatives seem to be theft, which no one seems to have had this problem. No temperature reading, but is correct pressure and temperature related?
Bob Weis
