2nd Gen Non-Engine/Transmission Smarty and setting "0"
2nd Gen Non-Engine/Transmission is it llegal?
JFulford
I've had a Smarty for my '02 for about a month now. Went through a tankful
on setting 1, the fuel saver and decided to try setting 0, 1/2 power, just to see what the difference would be. While it works and yes, my power is down quite a
bit, my 47RE shift and/or shift points are much higher. It seems to have moved the shift points up to 2500-2800 rpms, no matter how you accelerate.
It does seem to shift slightly better if I let off the accelerator at each point(like shifting with a manual), but not much. Is this just the way this setting works or is something else going on? I can switch from here to the other settings with no problems, so everything else seems to be working. 2002, 4. 10 gears, 47RE, 275RV injectors, 5" exhaust, stock tires.
jeff
level 0 for for emission testing purposes or for tuning down a higher powered truck
Level 0 is not really that great for a near stock truck for daily driving.
Half power on a stock truck = yugo type performance :-laf
Thanks for the quick response! Yep, I would say pretty low, but surely better than a yugo!;]
I guess I'll take it to 4 or 5; haven't tried those yet!
Thanks again,
jeff
What was the fuel mileage on sw 1, any improvement?
Just installed smarty , sw1.
Quite a differance in low end power, throttle seems more responsive,
And it's feel like I am controlling the IP not the computer, also seems to make shifting easier (6sd) I am able to match gear speed better .
Does sing when idling, high pitched diesel rattle. .
I plan to run a few hundred miles to check againt previous mileage:
20. 92 without smarty ,suburbs driving, lots of lights and some Interstate
RJWEST,
Sorry took so long to respond; too many hobbies.
My truck has never done very well, no matter what I do. I do mostly urban driving(not city but not highway). Without the smarty, I was getting around 14 average. With the Smarty on setting 1(and a 5" exhaust, and 275RVs, no way to change that) I got around 16(just shy). Before any addons at all, I got about 14. Smarty set on 5 got around 15. 5, but there was a little highway in there. This is all hand figured; computer is pretty far off.
I guess the combination of 4. 10s, automatic, and 4WD is killing me.
I've just filled and reset the Smarty to setting 3 for another test.
jeff
I tried the fuel saver last year for a day, and my driveablity was horrible. I don't think I gave it a fair go since my IP was on it's last leg and most of that day was spent in the Limp Home mode.
Ben
With my smarty on 9 I have seen a pretty consistent increase of about 2 mpg over my pre smarty mpg. More power and better economy what more could you ask for!!!
Towing 6K I gained 1MPG on SW3. Empty highway driving on SW1 also gained 1MPG. Not a huge improvement but I'll take it:D
The responsiveness of the higher softwares is unreal, way too much for towing.
John
