While trying out my Smarty Jr. after updating the version and data files, I found that the black smoke problem still exists about the same as before. I am assuming there must be something else causing the black smoke.
I have never experimented much with the Torque and Timing settings, but I found if I set the torque setting to stock it doesn't smoke nearly as much.
Could anyone clarify something for me? The manual that came with the Smarty Jr. concerning torque and timing settings is confusing and I thought someone might be able to list the settings in order from less to maximum.
Quoting the Torque settings from the manual : “ The torque settings can be programed 1-Stock, 2 Mild, 3 Soft (less than #2), 4-light ( less than #3)”
This sounds like if listed in order from least amount of torque to maximum torque would be: 1,4,3,2.
Quoting the Timing settings from the manual: “ The timing selection can be programed 1 - Stock, 2 - Smarty Standard, 3 – Mild (less than # 2), or 4 – Advanced (more than #2)”
This sounds like if listed in order from least amount of timing to the maximum timing would be: 1,3,2,4.
I guess Italians have a weird way of expressing themselves or I just have a hard time understanding them?? Do I have it right or wrong??
How much would altitude effect smoke? Altitude here in Albuquerque is about 5,500 Ft.
Possibly my injectors are getting a little worn with 135,000 miles on them, causing too much fuel to be injected resulting in smoke?
I appreciate any input regarding these questions.
