yes it raises boost levels mine saw over 40 psi on the dyno. when normally without the smarty the highest ive seen was 38 and that was a spike from the bullydog, after that it would settle around 30 psi. with the smarty it stayed at 40 plus.
the turbo is another weak link. as long as you dont keep pushing past 35 psi i dont see you having any issuses with it. what are your intentions with your truck?
also there is more load on everything with it.
