Test Drive Complete - WHOA BABY!
Guys - I've been all grins for about 3 hours now. I've got to say up front that words cannot describe how pleased I am with the way my truck performs now!
I really don't even know where to start.
I'm running Mach 5 injectors with an HTB2 62/14 with a Helix 2 camshaft. First off - I think the combination of the Smarty and the cam is really what made the difference in my truck.
Two words describe the feeling - "LIFT OFF!!!" :-laf Seriously, I let about 10 pounds of boost build up in 3rd and then I stomped on it, and the entire front of the truck lifted and never would "nose over" like it used to! It seriously threw my head (and whole body) back and planted me in my seat! I felt like I was "looking up" the whole time. I was pretty much going nuts - and my poor girlfriend was fearing for her life.
:-laf I first mashed it in 3rd, then went to fourth and pretty much stomped on it from the beginning, and once the turbo lit, there it went again! It was honestly like a jet taking off. The whole front of the truck lifted until I went to 5th. Spooled again with the same awesome results - I finally let out at 95 MPH and the truck never had nosed over - it was still pulling with PLENTY of throttle left!
Oo. It just kept on pulling in every gear.
I don't know how it all works together, but I think that the Smarty really unleashed the power of that cam. You normally hear of stronger top end and no "nose-overs" with a hot cam and that was really accented on SW #9 - MUCH more than with the Edge EZ. The top end fueling is just amazing on the Smarty. I can't wait to get it out on the Interstate early one morning and let it rip again.
Noticable Differences
1) Obviously, the above!
2) I don't think SW #9 is too touchy at all. I guess I've been used to feathering the throttle anyway, but I could actually stand to have more fuel down low - yes, I actually said that! And I think the reason is because the Smarty makes the throttle response much more proportionate to the accelerator position. Honestly, at first, I thought the turbo was taking longer to spool. But after I think about it, I think I just wasn't used to having to depress the throttle more to get the same results as I was used to. Does that make sense?
I don't think it drives like a hot 215-pumped 12V as some have reported, but the difference is like night and day.
3) This confuses me, and maybe Marco can explain this: When I cut my truck on, usually my lift pump (AirDog in my case) runs for about 3 seconds and primes to 17 pounds quickly and then holds that level to the end of the prime.
I noticed in each of the 4 starts tonight, that the pump only stays on for no more than 1 second and the pump only has time to prime to 10psi. Is this normal? I can't think of anything else that would be causing this. Also, it's like the pump cuts on for a split second, stumbles, and then jumps to 10psi. I actually thought something was wrong when I first turned the key on tonight.
Other than that, the pressure comes up just like normal after starting and the pressures while driving are exactly the same. Any thoughts?
4) I also got the trouble code that others have reported. I'm not crazy about this, but I can live with it. Maybe we can find a way around it in the future.
That's all I've got guys. I am completely satisfied with my purchase as you might have guessed, and I'm still in shock at the way the nose of the truck never did drop under acceleration. It's absolutely
awesome.
