Smarty Touch supplemental instructions
Fluidamper
Loss of fuel pressure
Does anyone have the supplemental instructions for the Smarty Touch showing what the Timing and Torque values mean? I reached out to the Smarty Pros website, but they don’t have them anymore. They sent the instructions for the S-06, but those values range from 0-4. The Touch ranges from 1-3, with a separate stock option. They assured me that the values changed with the firmware update to the VIN locked update (yes, I was running the old firmware!). But when I updated to the newer firmware my value options did not change.
Thanks,
Will
0=stock, 1-3 are the same.
The touch doesn’t have its own tuning, it’s the same as the S06 for your truck.
I find their instructions confusing, maybe this will help.
The first part may be true for the old firmware, but does not match the instructions from back in 2017 that I cannot find right now.
I understand what you are saying in the second part, but the timing and torque options of the Touch do not match the S06 or the Revo instructions posted by promisedland. After the update I only have 1-3 as options (see pictures below).
They get more aggressive the higher the number.
With your BBI Stage 1’s I’d run SW1, RP1, Timing 3, TQ 1 and see what you think.
Do you have any other engine mods that aren’t in your sig?
AH64ID,
Thanks for your help on this. I haven’t been on the forums for over 5-years, but I remember you being a wealth of information back then and it is great to see you still helping people.
I updated my sig before posting, so it is current. I will give those changes a try and see how it works.
Thanks,
Will
