smarty vs. edge juice
harsh transition from forward to reverse
2009 6.7l
Does anyone have any expreience in the comparison between the Smarty Jr. vs the Edge Juice chip on the 6. 7?? I have been running the edge for 4 years now and this summer it seems that I have lost power while towing. When push on a climb, the load% goes to 100 % fast and bogs down where in past years I held my speed on the same climbs with out being maxed out. I run the same two different routes to the mountains from home several times a year for the last 30 years, so I know the way the truck handles each climb. I am currently running the smarty as a test with the edge unplugged to see if it helps. It does idle smoother, but on level 2 and 3 it doesn't seem to be a whole lot better by feel. I haven't towed with it yet. It does appear to run cooler egt's like they claim.
Fuel pressures are 12-18 psi on low side, and the rail will go to 27,000psi without a problem. No smoke, map sensor is clean.
Anyone with comparison experience?
