Hi guys! Bob Wagner sent me a demo smarty to try out for week so i thought I'd compare the smarty with my edge juice in two catagories. The two catagories most important to me that is. 1. Fuel Economy 2. Power.
To start, when I conducted the test with the smarty I went a total of 1200 miles towing a 2K trailer. Not a lot but enough.
So, fuel economy was good with the smarty on #3. I averaged about 16MPG for the whole trip which is better than what I've been averaging empty with the edge juice w/attitude. After removing the smarty and sending it back to bob, I ran the same test with the edge only empty this time. I'm pretty disapointed. I'm averaging 13MPG if I'm lucky with the edge. If I'm soft on the pedal I'll get about 15MPG but with the smarty I was getting way better milage and didn't have worry so much about keeping a light foot. So for fuel economy, smarty gets a thumbs up and juice gets a thumbs down from me.
Here are my observations in power between the two. The juice definetly has the smarty beat off the line. The initial throttle response feels immediate with the juice. The smarty, however, did not fair so well in the initial take off from a complete stop. It took way more time for the turbo to spool with the smarty than the juice. After the turbo spool the tables changed quite a bit. The smarty had smooth solid power all the way through the curve. At WOT the juice seemed to be defueling the engine at a certain point, even with all the settings on the high and almost impossible side. The smarty seemed to lack the limitations of the juice, therefor giving a much better response at higher RPM. I could really feel the difference when I'd pass cars in overdrive. The smarty would really push you deep into the seat. With the juice, you'd either get an upshift or a not so dramatic acceleration.
Here are some other observations. The smarty continually set a P602 in the ECM. Not a big deal since you can clear them with the smarty. I like the monitoring capability of the edge juice w/attitude. I really wish edge would come out with something that would just monitor vitals off the map.
Although I was very impressed with the smarty, I did have one pretty major safety concern. A couple times, I'd be cruising with the throttle at a certain point and have to hit the brakes. I'd hit the brakes and the RPM's would stay right where I left them and the TC stayed locked for a lot longer than I'm confortable with, even when hitting the brakes. Almost put me into the back of a car on one occasion. This is something that definetly didn't happen with my juice or the stock ECM. It started happening when I loaded the smarty.
With this comparison, I just wanted to give my fellow TDR bretheren an unbias observation of these two products.
Will I stay with the Edge Juice or buy a smarty? As long as the TC and throttle thing is addressed, I'll probably buy a smarty and sell my juice but not until then.
