My wife's truck still has a problem and I can't seem to figure it out. Cold start in the morning there is excessive blue smoke and it will lasts a while (couple of miles). It also runs rough at start up. She says it seems like it is vibrating more than it used to cruising down the road at normal temp. I checked codes and there are none. I took out the manifold temp sensor and it was completely clean (that surprised me). There is no dead pedal associated with this problem so I am hoping it is not the VP. I am thinking it might be the injectors but what do you guys think?
On a side note is the cold start reflash a good one? (The one that bumps up the idle and runs the truck on 3 cylinders when cold. )
Thanks,
David
Thanks,
David
