So Long Oil Stinkies????
12cm turbo housing
Good Year Wrangler ATS 305's ?
I'm with you, I broke mine in with penzoil and at 25k switched to full synthetic, with no stinking for the first 500miles like the pe-u-zoil. #ad
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's,PowerMax3 adj. , A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, 310HP/675ft-lbs and more to come...
Maybe I'm crazy, but that's one of the things I like about doing an oil change. (c'mon, I know there are others out there that like the smell too) I was just thinking the other day that I won't get to smell that anymore when I switch to Amsoil and use extended drain intervals. #ad
B I G O R A N G E AMBER-FIRE (BURNT ORANGE) / BRITE SILVER 2001(. 5), 2500, SLT, Q-CAB 4x4, SWB, AUTO, 3. 55, LSD, TOWING PACKAGE
ADD-ON'S: LINE-X, 1/4" STEEL LONGHORN HITCH COVER, WESTIN NERF BARS, YELLOW-TOP OPTIMAS
Max, Is the 76 25% synthetic or what's the blend? I like the PB 2000 but wish it were a higher blend than 25%
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
Hey Alan -
I stumbled onto the 76 doing research on DELO... here's some of the information I found on 76 Royal Triton QLT
http://www.tosco.com/internet_pub/repository/lubes/44_Tn1_13.pdf
http://www.tosco.com/internet_pub/repository/lubes/44_Tn1_12a.pdf
(granted a lot of it's old and some of the competition has likely revised their formulations)
http://www.tosco.com/internet_pub/repository/lubes/40_royal_triton_qlt5.pdf
http://www.tosco.com/internet_pub/repository/lubes/18.html
My initial impression is favorable. I bought two 6 gallon cases of it and I'm pretty sure that the truck, the oil and I are going to be together for a good while. Looking forward to doing some hwy miles next month and maybe a little towing?
Max
Amsoil no stink. You get what you pay far.
2000 Dodge 4x4 Quad Cab SWB 5-SP
2001 VW NB TDI
AMSOIL(#504865) DEALER & USER
Flatonia...
Maybe I'll see ya at Grumpy's pass'n through there one of these days. Crew usually likes to pit there when traveling IH-10.
MaX
