Good Day Sir!
One problem right now is to check bottom side ECM cabling its a hell of a lot easier with tire off / wheel liner off. Having said that I am driving it also. I jumped to another task
to "get something" done.
I finally jumped the compressor by giving pin #87 12V + direct feed :-laf Charge system to +/- 30 oz of 134r. Now I know the compressor at least works when you force it too.
Can we say COLD, COLD. COLD air in those vents
Anyway I never really knew
how hot the condenser gets at idle. Let me tell you at first (for a few milliseconds) I honestly thought something was really wrong
in the "closed AC system" .. Then I got the H20 turned on and was watering the condenser
- turned up the idle an charged the system - after taking the H20 off the condenser
man did steam start coming up. Anyone would have thought my radiator cap / system is smoking lol.
Electric fans are a must to fix/tweak these systems correctly!
Back to my problem.
Checking voltage and ground issues in cab heater switch panel. The mirror and snowflake bottom does not come on. The fan/blower connection works and the instrument
panel lights and function all seem to work - and the new bulbs I put in the heater switch work.
Need to check the ECM wires between ECM and AC clutch relay.
Now that I have system charged I can see what voltage the pressure switch has and what the outbound voltage is.
Honestly I just wanted to change tracks an get other things which may hopefully bring me bac to the issue from the other side !
