Engine/Transmission (1998.5 - 2002) So who has the most miles on their lift pump?
2nd Gen Non-Engine/Transmission Storm damage
I have 114k miles on my pump so far, truck is stock. I don't have a guage, but mileage and power are both fine still. What's the most a lift pump has gone?
67k here, I have 275 hp injectors and a PM2 and the pump just keeps on going. 15/17psi at idle, and 8psi at WOT. :)
You might want to get a temporary gauge and give it a check though. Many of pumps have died and no one has known till it's too late. :(
My friend just picked up his 02 and I checked the pressure for him and it was only 6psi at WOT. :eek:
Give it a quik pressure check just to be safe. ;)
Darrell
Mine made it 131k. Fortunately cummins nw had one in stock so my truck was only down a couple of hours until i replaced it. Now that it has failed Im gonna install a pusher pump. Your lift pump will last a long time but way below minimum pressures. It is not wise to not give your injection pump an insufficient fuel supply. Check your pressure frequently or buy a guage. You will sleep better at night. I know i do.
How long
67k on my stock pump and it's going down hill. Readings were 12 @idle and 9 @wot, 10-11 cruising when I first added a gauge @ 35k. Now 0 sometimes but mostly 8 @idle and 5 @wot, 7@cruising. Time for a replacement.
I have 2 trucks
My 98 made it to 85K
My 2001 made it to 95K.
Both time the trucks kept running, just would not go very fast, and I was able to get to a dodge dealership.
Bob
brobeson - If it was to the point where you had that kind of driveability problem then your lift pumps were below the current spec of 8 psi min at WOT for a LOOOOONG time. I put at least 20,000 miles on my truck with no noticeable drivability problems with a bad lift pump. From my talks with vendors you have to get down into the 5-7 inches of VACUUM before you have those kind of problems.
WWadell - I'll bet you the cost of a replacement lift pump that if you put a fuel pressure gauge on your truck that you will find that your lift pump is well below the spec. EVERY single person that had significant mileage on their trucks (>50,000) and I asked if they'd checked their pressures and said "no, but it's driving fine" after they put a gauge on found their lift pump was bad. We're talking well over 20 people. I can't think of an event I've been to in the last two years that someone hasn't replaced their lift pump after finding out about the issue and checking it with a pressure gauge - and the vast majority of those were going down to ZERO psi of fuel pressure under load. Unless you put a gauge on your truck you simply cannot know whether you have a bad lift pump or not. There are a few lucky ones out there - but they are few and far between. `
Steve's got a point about the pres being down.
The lift pump I'm running only has 10k on it and it is about to fail. Today on the way home from a northern fishing trip it was acting up to the point I only saw 2psi @ cruise and comp off. The next step was to put on the coveralls and switch it out with a spare untill it came back to 10psi.
I'm trying to fiqure out how to get warranty out of cummins on this one with it being so wild . :mad:
41,000 and 14/12 PSI and I'm on borrowed time :{
My fuel pressure gauge is watched closely and I have a 7 PSI warning light that another TDR member told me how to install, it only was about $20 and gives me peace of mind, someting the llift pump never did. On a recent trip to Florida a borrowed lift rode under the back seat, just in case I couldnt make it to a dealership.
I had 89000 before the injector pump went. I have no idea when the lift pump died. I had no performance issues at all. I tow nearly every weekend going to/from horse shows. Then one day, leaving work, my truck made the most hideous sound. No more injector pump. Thank god for the warranty. $3000 for a new injector pump will hurt. Needless to say, gauges have been ordered and should be here today, and in by morning.
Originally posted by Pit Bull
Got to agree with Steve. Mine drove just fine. Put a guage on it and it had "0" PSI.
Amen and hail Mary... ...
Mine had 44K miles on it when it died yesterday. I had never had even a temp gauge, because I upgraded my fuel lines last year from the banjos to Webber fittings, and so had no place to plug in the Briar Hopper test gauge I bought a few months back.
Anyway, after having my SPA pressure gauge installed yesterday, the pump died. When I changed fuel filters less than 2K miles ago, it worked just fine, as it refilled the fuel filter cannister, which I always drain when changing the filter. Up until this point, I had *never* felt any surging, sputtering, or any other type of problems with the fueling system.
Just ordered a new one from Cummins West in Sacramento for $149.
Tom
My fuel pressure gauge saved me from walking and/or having to replace a failed VP44-I honestly don't know which is worse :rolleyes: . My personal opinion-I would NEVER run one of these trucks again without a fuel pressure gauge! When mine failed, it would start wildly fluctuating in pressure-after a while it would level out at a decent pressure. I can't help but wonder without a gauge how long it would have gone before total failure-I'm thinking not very long... ... .
Some people (not TDR members) I've talked to can't be bothered to run a gauge-or flat out refuse. Their prerogative-I've towed at least 1 of these guys home when his packed it in on a lease... ... .
Jason
Anybody know what Chrysler has done since 1998 with this system? What changes have been made to the lift pumps or systems since it was discovered as a weak area? Are the new trucks remedied? Has ANYTHING been set right in the last 4 years or does Chrysler just love warrentee work? George
Here's what I think George!
There have been I don't remember how many changes to the lift pump itself trying to remedy the problem... ... . IN MY OPINION (sorry to yell but I don't want somebody stomping my neck) the new pumps are better-but the idea of using an electric pump to try and suck fuel 10 feet and lift it to boot is insane! The on-block lift pump may work alright on a medium-duty truck (less distance to pull the fuel) or a farm tractor (tank is generally above the engine height-wise) but it's a godawful stupid idea on these trucks. Shame on Cummins engineering for perpetuating this setup to begin with-and DC engineering for not telling them to stick it where the sun shines and engineer a proper fix. Again IN MY OPINION, the only ways to fix the problem properly are 1. to add a pusher to feed the stocker, 2. remount the stocker down by the tank, or 3. go to an in-tank pump. I'm pursuing option # 3-probably a couple weeks though before I get around to it more seriously.....
Get a gauge man-you'll be better off for it!
Jason
Thanks Jason. A set of gages are high on my "first things first" list of improvements. I have 1300 miles now and want to start logging it's vitals. Then we tweak away... .
An intank pump makes me nervous regarding roadside repairs. I like the additional pump post tank idea. Has anyone been able to document the longevity with that solution? Just curious...
George
There's a thread or two floating around on here about pusher pumps and how many miles have been clocked in on them... ... . but I don't have it off the top of my head :) . Steve St. Laurent was the leader of the pack-hopefully he'll chime in here with the applicable thread.
Jason
