Engine/Transmission (1998.5 - 2002) So who has the most miles on their lift pump?
2nd Gen Non-Engine/Transmission Storm damage
I think you should have a gauge and monitor your lift pump. I would love to see some numbers on the number of 24V CTD on the road, average number of miles, and the number of dead VP44's.
Those of us that have come from the rotary Stanadyne in our Chevs and Fords considered the pump of 94-98 to rule then Cummins comes out with the VP-44, and it looks just like the old Stanadyne. I wonder what their life is with good lift pressure. I know they are definitely cheaper than the upright pump. GE
I just pulled a couple of threads back to the top.
First one is a poll on lift pump failures - https://www.turbodieselregister.com/forums/showthread.php?s=&postid=449070#post449070 - if you take out those that haven't checked their pressures and are just assuming they are good 37. 8% of the people had a lift pump failure before 50,000 miles and 15. 8% had a lift pump failure between 50,000-100,000 miles - that's out of 366 respondants. (again that's taking out the guys who haven't checked their pressures and are assuming they are good - if you put those in the failure rate is 31. 22% and 12. 9% with 442 responding - several of those guys since found failures and said so in the text)
The second one is asking who's had failures of the dual lift pump setup - https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=37897 . I have 50,000 miles on mine and my pressures haven't dropped at all. In the previous 60,000 miles I went through 4 lift pumps (and I bought the truck with 28,000 on it so I actually went through those four in 32,000 miles).
Here's a list of lift pump revisions that was posted by C1B1DIESEL a couple of months ago (thanks!):
here is a little history on the lift pumps and what changes were done to them and part Numbers. hope this helps
this is long. dont ask were it came from and i will not have to lie
CORRECTIVE ACTION SUMMARY
Below is a breif history of Lift Pump Part Number and associated
design/product changes:
12V 24V
3943467 3942802 Initial ISB Production
3944818 3942802 Added "saw cut" to the motor casing to better
detect leaks during production
3944508 Stainless Steel Valve Seat/Bronze Bushing for
the Internal Pressure Regulator
3945812 3945813 Some lift pumps were having a problem with
the internal wiring shorting to the magnet sleeve. The wiring
insulation was inadvertantly being
stripped from the wiring during assembly and during pump operation the
wires are shorting to the magnet sleeve.
Federal Mogul has changed the angularity of the wire lugs in the bottom
of the pump so the wires will enter behind the
magnet sleeve in a more direct manner, thereby reducing the chances of
stripping
the insulation. They also changed their end
of the line testing to look for this shorting problem during pump
operation. Federal Mogul is also adding a
radius to the top and the bottom of the magnet sleeve where the wires
travel behind the sleeve.
3948431 3948432 Corrosion of the connection of the pig tail
at the bottom of the pump was being seen. This was found to be to the
result of road salt acting as an electrolyte.
The electrical eye terminal was changed by the vendor from brass to
bronze. No corrosion is evident during similation
and salt fog tests with the bronze terminal. The mechanical properties
of the bronze meet or exceed that of the
brass and the vendor did conduct vibration test for further
verification. To further aid in corrosion
resistance, grease was added to each terminal at the Engine plant during
assembly.
3946151 3948070 The lift pump was updated with an
integral electrical connector. The integrated connector eliminates the
need for a pigtail type harness on the pump
and will eliminate the exposure of the pigtail to environmental elements.
Also updated was EMI reduction for the pump
due to an added capacitor to the internal circuit board and a Ferride bead
added to the connector.
3948431 (12V) and 3948432 (24V) where still
kept available for service because the wiring harness on older engines
where not long enough to plug into the integral adapter.
3938367 3938368 It was found the bearing material used
for the MFR. of bearings was not consistently uniform,leading to
variance in the pump performance. This
leads to change the bearing material to sintered iron from bronze.
There was also a change in armature shaft
geometry to straight one reduces the 100% inspection of the shafts.
These pumps have the integral connector.
For service, 3948431 (12V) was superceded to
3938435 (12V) and 3948434 (24V) was superceded to 3938436 (24V).
These pumps still maintain the pigtail wiring harness.
3990082 This is a service kit supercedes
3948431(12V). It includes 3938367 (12V) and a jumper harness (4025182) so
that it can be used on older engines with the
shorter lift pump connection wiring harness. 3938436 (24V) was superceded
to 3938368 (24V), but a kit was not created to
included the jumper harness, 4025182 must be ordered separately.
3990105 3990106 The lift pumps have been updated to include
hardened valve seat to reduce valve wear. The pump also reverts to a
prior use RFI circuit board due tocomponents being
detached and jamming the pump.
Service kit 3990082 was updated to include
3990105 (12V). 3938368 (24V) was superceded to 3990106 (24V), but a kit
was not created to included the jumper harness,
III. IMPLEMENTATION SUMMARY
The supplier started building pumps with these corrective actions in the
first week of May 2001. The latest lift pumps, part number 3990105 and
3990106 when into production
Steve, good summary. I guess now my question would be, how many failures with the latest pump? I have one of the 399105's and it is still working (only 9K miles on it but PSI is good). I am forced like many of us to stay stock to maintain my engine warranty, only have 49K on my truck.
OK OK I was trying to eat with one hand and type with the other with a client on the phone.
I need an intelligent octopus around here.
Yes, it would be good to see how the latest pump is doing. I probably have one, as DOB is 4/02. I actually read ALL the stuff Steve just posted and the question of how the new pump is doing seems to need an answer plus another question lurking in the back of my skull: Why don't we find a monster pump and put it at the tank like my Chev and forget the "sucker" pump. Chev lift pumps are not perfect but I do have 117K on a 93 mechanical Chev diesel and lift pump is fine. Somebody?? Am I going the right way here? GE
I'm looking into an Aeromotive electric pump. I've emailed thier tech dept. They replied:
"Leo,
Neither the 11203 or 13202 have been qualified with diesel fuel, so I can’t represent them as being determined compatible. I can tell you that many are using our pumps and regulators with diesel, and that includes the above p/n’s, with no unique problems to date. Good Luck!
Brett Clow
Aeromotive Tech Dept"
I have another mail into them for more info. I'm looking at a pump that can handle 18-20 psi w/ 150 GPH. THe pump can handle upto 70 psi with a simple spring change. I'm also looking into a pressure regulator to dial in the number.
One other thing I thought about. I read in some post somewhere that someone noticed performance changes when the banjo bolt holes were aligned with the line in. Also, there are kits for a -6AN line upgrade. I'm looking into -8 or -10 lines for the supply, simply because the VP44 uses the fuel for cooling and lube. No sense starving the VP44.
1999 Quadcab 5spd, 2WD (built 01-1999)currently has 153500 miles on original lift pump. Added fuel pressure gauge @ 140000 mi. - discovered high of 11psi @ idle & low of 6psi during extended W. O. T. acceleration - added Carter 7psi 100gph pusher. Now have 16psi+(gauge maxed out) @ idle & 12-14psi @ W. O. T. acceleration with DD UFM/Drag box set on 3x4 (original clutch won't hold anything higher in 4th & 5th).
That said... . lemme find some wood to knock on!!
6877
:D A gauge was put on mine at 26,000
6psi ideling 2psi wot not a clue this was
hapening. Dealer replaced no problem.
OL Ratlr. Oo.
good high mileage lift pump for sale
This is something that has been knawing on me for some time. If the VP44 is lubed and cooled by the excess fuel, wouldn't it be advantageous to run with a full tank most of the time, instead of almost empty?
About a year ago I came to that conclusion, and when on a long trip Inever use out of the factory tank, and if possible refill the bed tank when less than half empty. Sombody tell me if I am wrong:)
Finally checked mine proper--on the road with a Briar Hopper guage taped to the windshield. I could pull it to just under 2 pounds WOT.
Went to the dealer and they started their load of crap, so I went to Cummins and got one for 145 and swapped it out mydangself (didn't want those monkeys under my hood anyway). I picked up 4 lbs on all readings.
This was at 53k all stock. So I'm still under 8 WOT, with the latest part number.
YES a full tank does help. I regularly refuel at 1/2 tank and will keep doing so until I add a pusher.
