Spooled-up said:Check out the Extang Tonneau Covers
They have a great Warranty
I've got the Full-Tilt cover and it's great. No drilling, very secure, doesn't leak, and no modifications to the tailgate.
JARichard said:I am seriously thinking about getting a soft tonneau for my truck, What are you guys using and is there anything that attaches permanently to the tailgate.
Thanks!
JARichard said:How much did it set you back?
Do you guys have spray on bedliners with the tonneau cover? If so, did you go over or under the rails with the spray on liner!
KSams said:Just recently bought the Truxedo from Autoanything.com. I have the spray in bed liner and it works great. Just got back from S. Carolina where we had a couple of big downpours and everything stayed dry
bighammer said:I've had a Truxedo for a couple years now and still like it. I like the fact that I can cover things and keep them dry and out of sight. I can roll it up in just seconds for bigger things. I think the feature that sets it apart from the rest is VELCRO instead of snaps.Oo.
DGStrate said:Only thing that concerned me was:
1) the Truxedo mounting system left a fair amount inside the bed rails when rolled back... Sometimes I need the width to shoehorn 3 dirtbikes or a quad and a dirtbike next to each other (although it did have nice crisp edges and lines!)
and
2) You know how Velcro gets after being repeatedly opened/closed/opened/closed - It gets all frayed and does not hold well...
How is yours holding up after a couple years, and how often do you un-zip and re-close it?
Thanks in advance for the reply...
bighammer said:The one thing I did to it was to add foam pipe insulation to the bars that cross the bed. It stopped the noise of the cover sort of bouncing on the bars when on the highway with the rear window open.
DGStrate said:THAT is a good idea!
I think my Extang may get some of that, as long as it can stretch over the cross supports adequately. Other option is if the foam takes a little room, I could always put the supports in the winter (lower - looser) clip position...
Nice touch!
Glad the Velcro is still working for ya, and interesting if they do have the two versions... May have to check them out as a possibility in the future. Alothough, I am pretty spoiled by the "tilt" feature on my Extang!![]()
