Engine/Transmission (1998.5 - 2002) sometimes it starts
Engine/Transmission (1998.5 - 2002) Fuel module
2nd Gen Non-Engine/Transmission 1996 dodge 2500 frame dimensions
well the 02 started last night but when i shut it off and tried to restart it, it just cranks over and wont start. so could it be the ecm or a bad connection some where? fuel pumps out of the injecters when cracked. this has been an on going problem (read story in previous posts) truck starts every so often but not all the time help
check fuel pressure
and go from there
check the plugs going to the ecm push them in
and give her a try
or take the battery cables off both batterys for 30 min
clean everything up real good with sandpaper and a wire brush do it rite clean wires to the battery and grounds clean the red wire lug on the starter thats doing it rite
good luck and god bless
not getting fuel is the only thing I can think of
if it's turning over
Did you try swapping out the ASD and Fuel Injection relays like I suggested here?
You didn't say.
Good luck,
John L.
Have you tested the VP-44 by running +12 volts to pin #7 & -neg to pin #6 on the injection pump & try to start it?
