check it without a reader - I mean I thought there was a way to read the code on the dash with a key manipulation..... also where is a list of codes once we get it?????
Thanks
Thanks
BLACK PEARL said:The Key trick no longer works on the 2006 and newer. You have to use a code reader or take it to the dealer.
CDonaldson said:The key trick WORKS on my 2006. It took a couple tries to get it to work, but it DOES work.
CD
jam1on1 said:my 05 light went on the other morning it was a 0514 called dealer he says there is a fix but when they down load the fix it will program truck with the reverse horn recall i told him no thanks ill live with the cade until my new truck comes in
hammersley said:won't show the code... ... the light has went off and apparently he had the reflash done for the battery and low fuelline pressure,,,HOWEVER can one check online to seee ehat has been done with the truck?????
ALSO - since the light has went off - has the problem went away i. e. does he have to take it in to teh shop????????
